Aller au contenu principal
Toshiba Satellite C55D-A5304 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55D-A5304 RAM Replacement, RAM: étape 1, image 1 de 2 Toshiba Satellite C55D-A5304 RAM Replacement, RAM: étape 1, image 2 de 2
    • Turn off your laptop and make sure that it is not connected to any power source.
    • Put the laptop upside down so the back panel is facing you.
    • Remove the battery from the back of the computer.
  2. Toshiba Satellite C55D-A5304 RAM Replacement: étape 2, image 1 de 3 Toshiba Satellite C55D-A5304 RAM Replacement: étape 2, image 2 de 3 Toshiba Satellite C55D-A5304 RAM Replacement: étape 2, image 3 de 3
    • Find the backplate on the back of the laptop and unscrew the single, 5mm screw with a Philip Head Screwdriver.
    • Using your finger, go under the ledge of the back plate and take it off to expose the RAM.
  3. Toshiba Satellite C55D-A5304 RAM Replacement: étape 3, image 1 de 3 Toshiba Satellite C55D-A5304 RAM Replacement: étape 3, image 2 de 3 Toshiba Satellite C55D-A5304 RAM Replacement: étape 3, image 3 de 3
    • Once the RAM is exposed, use both hands to unlock the RAM and pull apart the metal pieces holding them in.
    • The card will pop out at an angle and you will need to carefully pull it out. If not using even pressure to remove the card, the RAM will be locked into the slot.
  4. Toshiba Satellite C55D-A5304 RAM Replacement: étape 4, image 1 de 1
    • You can insert your new RAM card into the slot very carefully. It will insert at an angle.
    • You can then push down on the flat face of the card and it will lock into place.
AbbyThorng
Membre depuis le 03/15/23
226 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 3-1, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 250
