Introduction
This guide will show you how to remove the motherboard from a Toshiba Satellite C55D-B5206 laptop. Do not be intimidated by the size and complexity of this motherboard, as it is relatively simple to remove.
Ce dont vous avez besoin
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
Remove all pieces of yellow polyimide tape that covers the connectors and cables on the motherboard.
