Introduction
If your keyboard is inoperable, use this guide to remove and replace the keyboard.
Ce dont vous avez besoin
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
Presque terminé !
