Aller au contenu principal
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: étape 1, image 1 de 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: étape 1, image 2 de 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: étape 1, image 3 de 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 2, image 1 de 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 3, image 1 de 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 3, image 2 de 2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 4, image 1 de 1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 5, image 1 de 1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 6, image 1 de 1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 7, image 1 de 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: étape 7, image 2 de 2
    • Pull the fan and heat sink away from the motherboard.
Laura Tamayo
Membre depuis le 02/14/19
678 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Leahy Spring 2019 Membre de l'équipe USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 329
