Aller au contenu principal
Toshiba Satellite C55Dt-A5306 Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55Dt-A5306  Fan Replacement, Battery: étape 1, image 1 de 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 2, image 1 de 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306  Fan Replacement, Back Cover: étape 3, image 1 de 1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 4, image 1 de 1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 5, image 1 de 1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 6, image 1 de 2 Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 6, image 2 de 2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306  Fan Replacement, Fan/Heatsink Replacement: étape 7, image 1 de 1
    • Using the Phillips Head #0 Screwdriver, unscrew four 3mm Phillips #0 screws, on the silver plate under the copper tubing.
  8. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 8, image 1 de 1
    • Using the Phillips Head #0 Screwdriver, remove two 1.5mm Phillips #0 screw holding the fan down.
  9. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 9, image 1 de 1
    • After unscrewing, remove the heatsink from the laptop.
  10. Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 10, image 1 de 2 Toshiba Satellite C55Dt-A5306  Fan Replacement: étape 10, image 2 de 2
    • Unplug connected wire to remove the fan as indicated. Both the heatsink and fan should be removed before replacement.
Nahrain Putris
Membre depuis le 01/17/17
329 Réputation
3 tutoriels rédigés
Équipe
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Membre de l'équipe Oakland University, Team 2-3, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G3
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 439
