Aller au contenu principal
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 2, image 1 de 1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 4, image 2 de 2
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 5, image 1 de 1
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 6, image 1 de 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 6, image 2 de 2
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 7, image 1 de 1
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 8, image 1 de 1
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 9, image 1 de 2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: étape 9, image 2 de 2
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
zeena qiryaqoz
Membre depuis le 01/17/17
301 Réputation
3 tutoriels rédigés
Équipe
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Membre de l'équipe Oakland University, Team 2-3, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G3
4 membres
14 tutoriels rédigés
Un commentaire
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 751
