Aller au contenu principal
Toshiba Satellite C655-S5142 Battery Replacement
  1. Toshiba Satellite C655-S5142 Battery Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C655-S5142 Battery Replacement, Battery: étape 1, image 2 de 2
    • Unplug your computer, and make sure that it is shut off before starting.
    • Flip over your laptop, making sure the battery is facing you.
  2. Toshiba Satellite C655-S5142 Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite C655-S5142 Battery Replacement: étape 2, image 2 de 2
    • On the right side of the laptop, push the switch to the right, and let go.
    • When replacing the battery, make sure the switch is to the right. After replacing it, push it back to the "locked" position.
  3. Toshiba Satellite C655-S5142 Battery Replacement: étape 3, image 1 de 2 Toshiba Satellite C655-S5142 Battery Replacement: étape 3, image 2 de 2
    • On the left side of the laptop, hold the switch to the left, and do not let go.
    • With the switch held, gently pull the battery out of the laptop.
    • When replacing the battery, you do not need to hold the left switch at all.
To replace the battery, gently insert it back into the laptop. Once it is secured, make sure both switches are in the “locked” position (pushed towards the battery).
Kyle Andrade
Membre depuis le 03/26/19
197 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G5, Valliere Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, Valliere Spring 2019
UMASSD-VALLIERE-S19S1G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 368
