Aller au contenu principal
Toshiba Satellite C655-S5142 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite C655-S5142 Keyboard Replacement: étape 2, image 2 de 2
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite C655-S5142 Keyboard Replacement: étape 3, image 2 de 2
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite C655-S5142 Keyboard Replacement: étape 4, image 2 de 2
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
Alex Kozlowski
Membre depuis le 03/21/19
244 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Valliere Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, Valliere Spring 2019
UMASSD-VALLIERE-S19S1G5
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 409
