Aller au contenu principal
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 1 de 1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: étape 2, image 1 de 1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: étape 3, image 1 de 1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
4 autres ont terminé cette réparation.
Shelby Kunz
Membre depuis le 04/19/13
57 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-20, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 4,845
