Aller au contenu principal
Toshiba Satellite C675-S7106 CMOS Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C675-S7106 CMOS Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 CMOS Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite C675-S7106 CMOS Battery Replacement: étape 2, image 2 de 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: étape 3, image 1 de 2 Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: étape 3, image 2 de 2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0-head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 CMOS Battery Replacement: étape 4, image 1 de 1
    • Using a thin pry tool, gently remove the battery from its socket.
Joshua Steakelum
Membre depuis le 03/25/19
451 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 282
