Aller au contenu principal
Toshiba Satellite C75D-A7370 Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C75D-A7370 Battery Replacement, Battery: étape 1, image 1 de 1
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 Battery Replacement: étape 2, image 1 de 2 Toshiba Satellite C75D-A7370 Battery Replacement: étape 2, image 2 de 2
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 Battery Replacement: étape 3, image 1 de 3 Toshiba Satellite C75D-A7370 Battery Replacement: étape 3, image 2 de 3 Toshiba Satellite C75D-A7370 Battery Replacement: étape 3, image 3 de 3
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
Chris Purdie
Membre depuis le 02/02/17
428 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 16-1, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 16-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G1
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 681
