Aller au contenu principal
Toshiba Satellite C855-S5115 DVD Tray Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C855-S5115 DVD Tray Replacement, Hard Drive: étape 1, image 1 de 1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  2. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 2, image 1 de 3 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 2, image 2 de 3 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 2, image 3 de 3
    • Pry the back panel out of the laptop using the spudger tool
  3. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 3, image 1 de 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 3, image 2 de 2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  4. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 4, image 1 de 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 4, image 2 de 2
    • Slide the HDD towards the sticker on the left.
  5. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 5, image 1 de 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 5, image 2 de 2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
  6. Toshiba Satellite C855-S5115 DVD Tray Replacement, DVD Tray: étape 6, image 1 de 1
    • Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
  7. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 7, image 1 de 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 7, image 2 de 2
    • Insert a plastic opening tool and follow the edges to open the panel.
  8. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 8, image 1 de 1
    • Once open, locate the CD tray indicated in this picture.
  9. Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 9, image 1 de 2 Toshiba Satellite C855-S5115 DVD Tray Replacement: étape 9, image 2 de 2
    • Lift the tray up and out.
Claire Fletcher
Membre depuis le 04/05/18
988 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 316
