Aller au contenu principal
Toshiba Satellite C855-S5115 Hard Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: étape 1, image 2 de 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 2, image 1 de 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 4, image 1 de 3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 4, image 2 de 3 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 4, image 3 de 3
    • Pry the back panel out of the laptop using the spudger tool
  5. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 5, image 2 de 2
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  6. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 6, image 2 de 2
    • Slide the HDD towards the sticker on the left.
  7. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 7, image 1 de 2 Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: étape 7, image 2 de 2
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
Claire Fletcher
Membre depuis le 04/05/18
964 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 21
Total : 1,319
