Aller au contenu principal
Toshiba Satellite C855D-S5109 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 2, image 1 de 2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 2, image 2 de 2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 3, image 1 de 3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 3, image 2 de 3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 3, image 3 de 3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: étape 4, image 1 de 2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: étape 4, image 2 de 2
    • Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
    • Remove the L-Shaped panel.
  5. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 5, image 1 de 2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 5, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the screw(s) securing the hard drive to the laptop case.
    • Carefully pull the tab on the hard drive to detach the connecting wire to the right of the hard drive.
    • Remove the hard drive.
  6. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: étape 6, image 1 de 2 Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: étape 6, image 2 de 2
    • Remove the twelve 6 mm screws from the back of the laptop with a Phillips #00 screwdriver.
    • There are 12 screws holding the back panel on the laptop. Two of the screws are located underneath the service panel.
  7. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 7, image 1 de 3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 7, image 2 de 3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 7, image 3 de 3
    • Remove the DVD RW Drive by sliding it out.
    • Use a jimmy to pry open the back panel.
    • Pull the back panel of the laptop off, exposing the motherboard and other inside components.
  8. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 8, image 1 de 3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 8, image 2 de 3 Toshiba Satellite C855D-S5109 Cooling Fan Replacement: étape 8, image 3 de 3
    • The cooling fan is in the bottom right corner of the laptop.
    • Unplug the small red and blue wire connecting the cooling fan to the motherboard.
    • Remove the two 3 mm screws securing the fan to the motherboard with a Phillips #00 screwdriver.
    • Remove the fan from the laptop.
Brook Ostrander
Membre depuis le 09/27/21
169 Réputation
2 tutoriels rédigés
Équipe
Casper College, Team 1-3, Lareau Fall 2021 Membre de l'équipe Casper College, Team 1-3, Lareau Fall 2021
CASC-LAREAU-F21S1G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 295
