Aller au contenu principal
Toshiba Satellite C855D-S5303 Disc Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: étape 1, image 1 de 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: étape 1, image 2 de 3 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: étape 1, image 3 de 3
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: étape 2, image 1 de 1
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite C855D-S5303 Disc Drive Replacement: étape 3, image 2 de 2
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Courtney Burns
Membre depuis le 10/20/16
836 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 355
