Aller au contenu principal
Toshiba Satellite CL15t-B1204X Power Connector Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 2, image 1 de 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 3, image 1 de 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 4, image 1 de 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 5, image 1 de 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 6, image 1 de 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: étape 7, image 1 de 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: étape 7, image 2 de 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: étape 7, image 3 de 3
    • Disconnect the charging connector from the motherboard using the blue iFixIt opening tool by sliding it away from the connector.
  8. Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 8, image 1 de 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 8, image 2 de 3 Toshiba Satellite CL15t-B1204X Power Connector Replacement: étape 8, image 3 de 3
    • Pry the power connector upwards from the side of the laptop using the opening tool, then remove the part from the laptop.
Matthew Hook
Membre depuis le 03/25/19
439 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S1-G6, Hovde Fall 2019 Membre de l'équipe IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 276
