Aller au contenu principal
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 2, image 1 de 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 3, image 1 de 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 4, image 1 de 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 5, image 1 de 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 6, image 1 de 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: étape 7, image 1 de 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: étape 7, image 2 de 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: étape 7, image 3 de 3
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 8, image 1 de 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 8, image 2 de 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 9, image 1 de 2 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 9, image 2 de 2
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 10, image 1 de 1
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 11, image 1 de 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 11, image 2 de 3 Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: étape 11, image 3 de 3
    • Open the laptop and remove the display assembly from the keyboard assembly.
Matthew Hook
Membre depuis le 03/25/19
439 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S1-G6, Hovde Fall 2019 Membre de l'équipe IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 309
