Aller au contenu principal
Toshiba Satellite Click 2 L35W-B3204 Screen Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: étape 1, image 1 de 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: étape 1, image 2 de 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: étape 1, image 3 de 3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 2, image 1 de 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 2, image 2 de 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
  3. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 3, image 1 de 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 3, image 2 de 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 3, image 3 de 3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: étape 4, image 1 de 1
    • Your screen is now completely detached from the internal components.
2 autres ont terminé cette réparation.
Lexi Lannigan
Membre depuis le 10/17/18
753 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G4, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G4
6 membres
12 tutoriels rédigés
Un commentaire
This instruction set was VERY useful, since it focused on the exact device that I have, and had great photos to accompany the steps. TC
Thomas Cirillo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 1,655
