Aller au contenu principal
Toshiba Satellite E105-S1602 Display Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E105-S1602 Display Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement, Battery: étape 1, image 2 de 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Display Replacement: étape 2, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 2, image 2 de 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Display Replacement, Keyboard: étape 3, image 1 de 3 Toshiba Satellite E105-S1602 Display Replacement, Keyboard: étape 3, image 2 de 3 Toshiba Satellite E105-S1602 Display Replacement, Keyboard: étape 3, image 3 de 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Display Replacement: étape 4, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 4, image 2 de 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Display Replacement: étape 5, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 5, image 2 de 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Display Replacement: étape 6, image 1 de 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Display Replacement: étape 7, image 1 de 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Display Replacement: étape 8, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 8, image 2 de 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Display Replacement, Front Panel: étape 9, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement, Front Panel: étape 9, image 2 de 2
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Display Replacement: étape 10, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 10, image 2 de 2
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Display Replacement: étape 11, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 11, image 2 de 2
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Display Replacement: étape 12, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 12, image 2 de 2
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Display Replacement: étape 13, image 1 de 3 Toshiba Satellite E105-S1602 Display Replacement: étape 13, image 2 de 3 Toshiba Satellite E105-S1602 Display Replacement: étape 13, image 3 de 3
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Display Replacement: étape 14, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 14, image 2 de 2
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Display Replacement: étape 15, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 15, image 2 de 2
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Display Replacement: étape 16, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 16, image 2 de 2
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Display Replacement: étape 17, image 1 de 1
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
  18. Toshiba Satellite E105-S1602 Display Replacement, Display: étape 18, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement, Display: étape 18, image 2 de 2
    • Rotate the computer so the screen is facing you and locate the four plastic screw covers; one at each corner of the screen
    • Using your fingernail, remove each cover in order to expose the screw.
  19. Toshiba Satellite E105-S1602 Display Replacement: étape 19, image 1 de 1
    • Remove the four Philips #00 4.85mm screws located at each corner of the screen.
  20. Toshiba Satellite E105-S1602 Display Replacement: étape 20, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 20, image 2 de 2
    • Insert the plastic opening tool in between the screen and the case to peel the plastic case away from the screen.
    • Lift the plastic case away from the rest of the screen.
  21. Toshiba Satellite E105-S1602 Display Replacement: étape 21, image 1 de 3 Toshiba Satellite E105-S1602 Display Replacement: étape 21, image 2 de 3 Toshiba Satellite E105-S1602 Display Replacement: étape 21, image 3 de 3
    • Locate and remove the two Philips #00 5.65 mm screws in the bottom right and bottom left corners of the screen.
    • The screw in the bottom left corner is attached to a black and white cord in the back casing.
    • To remove the cord from the motherboard, grip the sides of the cord and pull up from the motherboard.
  22. Toshiba Satellite E105-S1602 Display Replacement: étape 22, image 1 de 2 Toshiba Satellite E105-S1602 Display Replacement: étape 22, image 2 de 2
    • Locate and remove the eight Philips #00 5.65 mm screws, four on either side of the screen.
    • Lift the screen away from the rest of the laptop.
Ian Washburne
Membre depuis le 01/11/13
59 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-21, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,660
