Aller au contenu principal
Toshiba Satellite E45-B4100 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Battery Replacement: étape 1, image 1 de 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Cooling Fan Replacement: étape 2, image 1 de 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Cooling Fan: étape 3, image 1 de 1
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Cooling Fan Replacement: étape 4, image 1 de 2 Toshiba Satellite E45-B4100 Cooling Fan Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    Pro Tech Toolkit
    $74.95
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD safe tools, we recommend using the iFixit Pro Tech Toolkit.
  5. Toshiba Satellite E45-B4100 Cooling Fan Replacement: étape 5, image 1 de 1
    • Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
  6. Toshiba Satellite E45-B4100 Cooling Fan Replacement: étape 6, image 1 de 1
    • Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
  7. Toshiba Satellite E45-B4100 Cooling Fan Replacement: étape 7, image 1 de 1
    • Remove the attachment from the Processor by gently rotating and lifting.
Brendan Sweeney
Membre depuis le 10/11/16
182 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 630
