Aller au contenu principal
Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, Battery Replacement: étape 1, image 1 de 1
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: étape 2, image 1 de 1
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: étape 3, image 1 de 3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: étape 3, image 2 de 3 Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement, USB Port Circuit Board: étape 3, image 3 de 3
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend the iFixit toolkit.
  4. Toshiba Satellite E45-B4100 USB Port Circuit Board Replacement: étape 4, image 1 de 1
    • Using the #0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive and remove the USB Port Circuit Board as shown.
Tori Ryals
Membre depuis le 10/11/16
41 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 431
