Aller au contenu principal
Toshiba Satellite E45t-B4204 Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: étape 1, image 1 de 3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: étape 1, image 2 de 3 Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: étape 1, image 3 de 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Fan Replacement: étape 2, image 1 de 2 Toshiba Satellite E45t-B4204 Fan Replacement: étape 2, image 2 de 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Fan Replacement: étape 3, image 1 de 3 Toshiba Satellite E45t-B4204 Fan Replacement: étape 3, image 2 de 3 Toshiba Satellite E45t-B4204 Fan Replacement: étape 3, image 3 de 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Fan Replacement, Fan: étape 4, image 1 de 1
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  5. Toshiba Satellite E45t-B4204 Fan Replacement: étape 5, image 1 de 3 Toshiba Satellite E45t-B4204 Fan Replacement: étape 5, image 2 de 3 Toshiba Satellite E45t-B4204 Fan Replacement: étape 5, image 3 de 3
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  6. Toshiba Satellite E45t-B4204 Fan Replacement: étape 6, image 1 de 2 Toshiba Satellite E45t-B4204 Fan Replacement: étape 6, image 2 de 2
    • Locate the red, black, and yellow wire connecting to the motherboard.
  7. Toshiba Satellite E45t-B4204 Fan Replacement: étape 7, image 1 de 3 Toshiba Satellite E45t-B4204 Fan Replacement: étape 7, image 2 de 3 Toshiba Satellite E45t-B4204 Fan Replacement: étape 7, image 3 de 3
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
Perla Ruiz
Membre depuis le 03/22/18
159 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S17-G4, Blackburne Spring 2018 Membre de l'équipe Sam Houston State, Team S17-G4, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 289
