Aller au contenu principal
Toshiba Satellite E45t-B4204 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45t-B4204 RAM Replacement, Back Case: étape 1, image 1 de 3 Toshiba Satellite E45t-B4204 RAM Replacement, Back Case: étape 1, image 2 de 3 Toshiba Satellite E45t-B4204 RAM Replacement, Back Case: étape 1, image 3 de 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite E45t-B4204 RAM Replacement: étape 2, image 2 de 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 RAM Replacement: étape 3, image 1 de 3 Toshiba Satellite E45t-B4204 RAM Replacement: étape 3, image 2 de 3 Toshiba Satellite E45t-B4204 RAM Replacement: étape 3, image 3 de 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 RAM Replacement, RAM: étape 4, image 1 de 3 Toshiba Satellite E45t-B4204 RAM Replacement, RAM: étape 4, image 2 de 3 Toshiba Satellite E45t-B4204 RAM Replacement, RAM: étape 4, image 3 de 3
    • Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM.
  5. Toshiba Satellite E45t-B4204 RAM Replacement: étape 5, image 1 de 3 Toshiba Satellite E45t-B4204 RAM Replacement: étape 5, image 2 de 3 Toshiba Satellite E45t-B4204 RAM Replacement: étape 5, image 3 de 3
    • On the ends of the RAM, there are small clips. Click the small clips by pushing them away from from the RAM. Once the RAM has been clicked off gently pull out and remove.
Eduardo
Membre depuis le 03/22/18
411 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team S17-G4, Blackburne Spring 2018 Membre de l'équipe Sam Houston State, Team S17-G4, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 855
