Aller au contenu principal
Toshiba Satellite E45t-B4204 Speaker Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: étape 1, image 1 de 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: étape 1, image 2 de 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: étape 1, image 3 de 3
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: étape 2, image 1 de 2 Toshiba Satellite E45t-B4204 Speaker Replacement: étape 2, image 2 de 2
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: étape 3, image 1 de 3 Toshiba Satellite E45t-B4204 Speaker Replacement: étape 3, image 2 de 3 Toshiba Satellite E45t-B4204 Speaker Replacement: étape 3, image 3 de 3
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: étape 4, image 1 de 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: étape 4, image 2 de 3 Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: étape 4, image 3 de 3
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: étape 5, image 1 de 1
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: étape 6, image 1 de 1
    • Remove the speakers.
Emily Bateman
Membre depuis le 05/22/19
97 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G3, Wilson Summer 2019 Membre de l'équipe IUPUI, Team S3-G3, Wilson Summer 2019
IUPUI-WILSON-SU19S3G3
4 membres
6 tutoriels rédigés
2 commentaires
Thanks for the guide, but looks is missing some main parts, the product code of the speaker.⏎
Before I disassembly something I want to buy the replacement, by searching for "toshiba e45-b4200 speaker" I only find some presumably compatible speakers, with different shape.⏎
Any idea of what is the product code?⏎
Thanks
MagenOne - Réponse
Looks this H000079200
MagenOne -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 694
