Aller au contenu principal
Toshiba Satellite E45t-B4300 Speakers Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite E45t-B4300 Speakers Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite E45t-B4300 Speakers Replacement, Battery: étape 1, image 2 de 2
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Speakers Replacement: étape 2, image 1 de 1
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Speakers Replacement, Bottom Case: étape 3, image 1 de 1
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Speakers Replacement: étape 4, image 1 de 1
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Speakers Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Speakers Replacement: étape 6, image 1 de 1
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Speakers Replacement, Speakers: étape 7, image 1 de 1
    • Remove the two 7mm screws with a Phillips #0 screwdriver.
  8. Toshiba Satellite E45t-B4300 Speakers Replacement: étape 8, image 1 de 1
    • Remove the following two 7mm screws with a Phillips #0 screwdriver
  9. Toshiba Satellite E45t-B4300 Speakers Replacement: étape 9, image 1 de 1
    • Use tweezers or your fingers to disconnect the speakers from the motherboard.
    • Remove speakers.
Joshua Swanson
Membre depuis le 02/20/17
701 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S2-G2, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
3 membres
12 tutoriels rédigés
2 commentaires
Where are these speakers available to buy
Paul T - Réponse
I'm looking for it too (mine is a E45-B4200) but I only find fake ones.
At this point I'm going to try to fix the membrane with some kind of flexible glue.
MagenOne -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 514
