Aller au contenu principal
Toshiba Satellite L15W-B1208X Battery Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L15W-B1208X Battery Replacement, Battery: étape 1, image 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Battery Replacement: étape 2, image 1 de 3 Toshiba Satellite L15W-B1208X Battery Replacement: étape 2, image 2 de 3 Toshiba Satellite L15W-B1208X Battery Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Battery Replacement: étape 3, image 1 de 3 Toshiba Satellite L15W-B1208X Battery Replacement: étape 3, image 2 de 3 Toshiba Satellite L15W-B1208X Battery Replacement: étape 3, image 3 de 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Battery Replacement: étape 4, image 1 de 3 Toshiba Satellite L15W-B1208X Battery Replacement: étape 4, image 2 de 3 Toshiba Satellite L15W-B1208X Battery Replacement: étape 4, image 3 de 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 638
