Aller au contenu principal
Toshiba Satellite L15W-B1208X Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 3, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 3, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 3, image 3 de 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 4, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 4, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 4, image 3 de 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
  5. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Sound Board: étape 5, image 1 de 2 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Sound Board: étape 5, image 2 de 2
    • Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
  6. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 6, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 6, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the ESD Safe Tweezers Blunt Nose gently pull on the plastic connector that attaches the speaker wiring to the soundboard to disconnect the soundboard from the laptop.
    • Gently pull the wire away from the soundboard using the ESD Safe Tweezers Blunt Nose.
  7. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 7, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 7, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 7, image 3 de 3
    • Gently lift the soundboard out of the laptop.
  8. Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: étape 8, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: étape 8, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement, Hard Drive: étape 8, image 3 de 3
    • Pull up on the ribbon beneath the hard drive to lift the hard drive upwards.
  9. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 9, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 9, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 9, image 3 de 3
    • Gently pull the hard drive towards the edge of the laptop to disconnect the hard drive from the laptop circuitry.
  10. Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 10, image 1 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 10, image 2 de 3 Toshiba Satellite L15W-B1208X Hard Drive Replacement: étape 10, image 3 de 3
    • Remove the hard drive from black rubber mount by pulling the corner of the rubber mount away from the hard drive.
    • Continue pulling the rubber mount away from the hard drive until all four corners have been taken off.
    • Pull the remainder of the rubber mount away from the hard drive.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 516
