Aller au contenu principal
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: étape 1, image 1 de 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: étape 1, image 2 de 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: étape 1, image 3 de 3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: étape 2, image 1 de 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: étape 2, image 2 de 3 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: étape 2, image 3 de 3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: étape 3, image 1 de 1
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: étape 4, image 1 de 1
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: étape 5, image 1 de 1
    • Remove the board from the laptop.
Yanchen Li
Membre depuis le 01/22/20
121 Réputation
1 tutoriel rédigé
Équipe
York University, Team S8-G2, Turner Winter 2020 Membre de l'équipe York University, Team S8-G2, Turner Winter 2020
YORK-TURNER-W20S8G2
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 346
