Aller au contenu principal
Toshiba Satellite L15W-B1320 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite L15W-B1320 Hard Drive Replacement: étape 2, image 3 de 3
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: étape 4, image 1 de 1
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
Elizabeth Zapata
Membre depuis le 09/25/17
190 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 12
30 derniers jours : 17
Total : 1,291
