Aller au contenu principal
Toshiba Satellite L305-S5875 CCFL Tube Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, LCD Screen: étape 1, image 1 de 1
    • Open the laptop so that you can see the screen.
  2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 2, image 1 de 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 2, image 2 de 2
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 3, image 1 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 3, image 2 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 3, image 3 de 3
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 4, image 1 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 4, image 2 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 4, image 3 de 3
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  5. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 5, image 1 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 5, image 2 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 5, image 3 de 3
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  6. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 6, image 1 de 1
    • Congratulations, you have just removed your screen!
  7. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: étape 7, image 1 de 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: étape 7, image 2 de 2
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  8. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 8, image 1 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 8, image 2 de 3 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 8, image 3 de 3
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  9. Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 9, image 1 de 2 Toshiba Satellite L305-S5875 CCFL Tube Replacement: étape 9, image 2 de 2
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
Tyler
Membre depuis le 03/11/14
208 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Calaway Spring 2014 Membre de l'équipe UMass Dartmouth, Team 3-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 585
