Aller au contenu principal
Toshiba Satellite L305-S5875 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5875 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 2, image 3 de 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 2 Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 2
    • Flip the laptop over so that you can see the back. Make sure that the volume scroller is closest to you when it is flipped over.
    • Locate the hard drive compartment. This is in the bottom left hand side of the laptop.
    • Remove the two 5 mm type-0 Phillips head screws that secure the door and save them to a safe location.
    • Remove the hard drive cover.
  4. Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 4, image 1 de 2 Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 4, image 2 de 2
    • With the small door removed, find the black ribbon that is attached to the hard drive tray.
    • Carefully pull the ribbon to the left so that the hard drive tray slides out neatly.
  5. Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the four 4.2 mm type-0 Phillips head screws located on the side of the hard drive enclosure.
  6. Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite L305-S5875 Hard Drive Replacement: étape 6, image 2 de 2
    • Remove the hard drive from the tray.
    • Make sure that when you slide the tray back into place, that the ribbon remains easily accessible.
David Zhuo
Membre depuis le 01/11/13
35 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 20-5, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 2,378
