Aller au contenu principal
Toshiba Satellite L305-S5875 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5875 RAM Replacement, Battery: étape 1, image 1 de 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 RAM Replacement: étape 2, image 1 de 3 Toshiba Satellite L305-S5875 RAM Replacement: étape 2, image 2 de 3 Toshiba Satellite L305-S5875 RAM Replacement: étape 2, image 3 de 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 RAM Replacement, RAM: étape 3, image 1 de 3 Toshiba Satellite L305-S5875 RAM Replacement, RAM: étape 3, image 2 de 3 Toshiba Satellite L305-S5875 RAM Replacement, RAM: étape 3, image 3 de 3
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  4. Toshiba Satellite L305-S5875 RAM Replacement: étape 4, image 1 de 3 Toshiba Satellite L305-S5875 RAM Replacement: étape 4, image 2 de 3 Toshiba Satellite L305-S5875 RAM Replacement: étape 4, image 3 de 3
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
3 autres ont terminé cette réparation.
Elliot Fiske
Membre depuis le 01/30/13
36 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 20-5, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 9
Total : 6,840
