Aller au contenu principal
Toshiba Satellite L305-S5946 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5946 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 2, image 1 de 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 3, image 1 de 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 3, image 2 de 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 3, image 3 de 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 5, image 1 de 2 Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 5, image 2 de 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 6, image 1 de 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 6, image 2 de 3 Toshiba Satellite L305-S5946 Hard Drive Replacement: étape 6, image 3 de 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
4 autres ont terminé cette réparation.
Alec
Membre depuis le 04/18/13
352 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-49, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
4 membres
19 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 2,195
