Aller au contenu principal
Toshiba Satellite L305-S5955 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: étape 1, image 1 de 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: étape 2, image 1 de 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite L305-S5955 Keyboard Replacement: étape 4, image 2 de 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: étape 5, image 1 de 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: étape 6, image 1 de 2 Toshiba Satellite L305-S5955 Keyboard Replacement: étape 6, image 2 de 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
2 autres ont terminé cette réparation.
Chris
Membre depuis le 09/30/14
1 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-2, Buehl Fall 2014 Membre de l'équipe Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 957
