Aller au contenu principal
Toshiba Satellite L305-S5955 Wireless Card Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: étape 1, image 1 de 1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 2, image 1 de 1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: étape 3, image 1 de 1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 4, image 1 de 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 4, image 2 de 2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 5, image 1 de 1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 6, image 1 de 2 Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 6, image 2 de 2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: étape 7, image 1 de 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: étape 7, image 2 de 3 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: étape 7, image 3 de 3
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 8, image 1 de 1
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: étape 9, image 1 de 1
    • Pull the card out vertically.
Samuel Baker
Membre depuis le 01/30/17
307 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Baechle Spring 2017 Membre de l'équipe IUPUI, Team 1-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G2
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 820
