Aller au contenu principal
Toshiba Satellite L305D-S5895 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5895 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 2, image 2 de 2
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 3, image 2 de 2
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 4, image 1 de 1
    • Lift the keyboard up in order to remove the cable.
  5. Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 5, image 1 de 3 Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 5, image 2 de 3 Toshiba Satellite L305D-S5895 Keyboard Replacement: étape 5, image 3 de 3
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
Tyler GLick
Membre depuis le 10/21/16
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 8
Total : 365
