Aller au contenu principal
Toshiba Satellite L305D-S5895 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5895 RAM Replacement, RAM: étape 1, image 1 de 2 Toshiba Satellite L305D-S5895 RAM Replacement, RAM: étape 1, image 2 de 2
    • You will use your P0 screwdriver attachment to undo this screw.
    • Undo the screw using the screwdriver.
  2. Toshiba Satellite L305D-S5895 RAM Replacement: étape 2, image 1 de 1
    • Use your finder to pry the cover up.
    • You will feel the cover pop up. This is normal.
  3. Toshiba Satellite L305D-S5895 RAM Replacement: étape 3, image 1 de 3 Toshiba Satellite L305D-S5895 RAM Replacement: étape 3, image 2 de 3 Toshiba Satellite L305D-S5895 RAM Replacement: étape 3, image 3 de 3
    • You should now be able to see two silver tabs.
    • Use two fingers to push these tabs away from each other.
    • The RAM stick should pop up at about a 30 degree angle.
  4. Toshiba Satellite L305D-S5895 RAM Replacement: étape 4, image 1 de 1
    • You should now be able to remove the first RAM stick by pulling it out in the direction of the long elevated side.
  5. Toshiba Satellite L305D-S5895 RAM Replacement: étape 5, image 1 de 3 Toshiba Satellite L305D-S5895 RAM Replacement: étape 5, image 2 de 3 Toshiba Satellite L305D-S5895 RAM Replacement: étape 5, image 3 de 3
    • You should now be able to see the second pair of tabs for the second RAM stick.
    • The second RAM stick should now be sitting at about a 30 degree angle.
  6. Toshiba Satellite L305D-S5895 RAM Replacement: étape 6, image 1 de 1
    • You can now remove this RAM stick by pulling on the long elevated side of the RAM stick.
To reassemble your device, follow these instructions in reverse order. Make sure that you have the RAM stick in the correct orientation when attempting to put it back in place.
Daniel Matheson
Membre depuis le 10/19/16
355 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 7
Total : 294
