Aller au contenu principal
Toshiba Satellite L305D-S5900 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5900 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly.
    • The plastic strip boxed in red is located above the keyboard of the computer.
  2. Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 2, image 1 de 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 2, image 2 de 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 2, image 3 de 3
    • There are three points of contact boxed in red needed to release located at the far left, the far right and the middle of the plastic strip.
    • Remove the plastic strip from one far end progressively towards the other end using a metal spludger.
  3. Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 3, image 2 de 2
    • Remove the two 5.3 mm Phillips #1 screws that are beneath the strip.
    • The screws located at the far left and far right when the plastic strip is removed.
  4. Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 4, image 2 de 2
    • Use the metal spludger to push the keyboard in the direction of the track pad and then lift the keyboard up.
    • Be careful not to pull too fast as there is still another cable attaching the keyboard.
  5. Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 5, image 1 de 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 5, image 2 de 3 Toshiba Satellite L305D-S5900 Keyboard Replacement: étape 5, image 3 de 3
    • There are two tab boxed in red is located at each side of the ZIF (zero insertion force) connector.
    • Use a metal spludger to push the tab upward in order to release the cable ribbon.
    • Carefully pull out the ribbon cable from the ZIF (zero insertion force) connector.
Sing Yang Cheng
Membre depuis le 10/20/16
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 329
