Aller au contenu principal
Toshiba Satellite L305D-S5900 Storage Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: étape 2, image 1 de 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: étape 2, image 2 de 3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: étape 2, image 3 de 3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: étape 3, image 2 de 2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Sing Yang Cheng
Membre depuis le 10/20/16
501 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 338
