Aller au contenu principal
Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: étape 1, image 1 de 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 2, image 1 de 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 2, image 2 de 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 3, image 2 de 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: étape 5, image 1 de 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: étape 5, image 2 de 2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 6, image 1 de 1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 7, image 1 de 2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 7, image 2 de 2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 8, image 1 de 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 8, image 2 de 3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: étape 8, image 3 de 3
    • To separate the hard drive from the caddy, unscrew the two screws.
Ricky Baker
Membre depuis le 03/26/14
217 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 1-2, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 14
Total : 877
