Aller au contenu principal
Toshiba Satellite L305D-S5950 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L305D-S5950 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 2, image 2 de 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 3, image 2 de 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: étape 5, image 1 de 2 Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: étape 5, image 2 de 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 6, image 1 de 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 7, image 1 de 3 Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 7, image 2 de 3 Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 7, image 3 de 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Keyboard Replacement: étape 8, image 1 de 1
    • Remove the keyboard completely from the laptop.
William
Membre depuis le 03/26/14
889 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 1-2, Benson Spring 2014 Membre de l'équipe Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
3 membres
10 tutoriels rédigés
Un commentaire
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
pamtinkle - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 553
