Introduction
In order to replace the motherboard the hard drive, RAM, keyboard and motherboard cover need to be removed.
Outils
Pièces
Aucune pièce nécessaire.
Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
Unplug all the wires indicated by the orange squares.
Annulation : je n'ai pas terminé ce guide.
2 autre(s) ont terminé cette réparation.
