Aller au contenu principal
Toshiba Satellite L35-S2174 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 2, image 1 de 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 3, image 2 de 2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 4, image 1 de 1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: étape 5, image 1 de 3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: étape 5, image 2 de 3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: étape 5, image 3 de 3
    • Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 6, image 1 de 2 Toshiba Satellite L35-S2174 Hard Drive Replacement: étape 6, image 2 de 2
    • Slide the hard drive to the left to detach it from the computer.
    • Lift the hard drive from the computer.
Amani Mitchell
Membre depuis le 10/18/16
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-4, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 598
