Aller au contenu principal
Toshiba Satellite L45-S7423 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 2, image 1 de 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 3, image 1 de 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 3, image 2 de 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • Remove the two Phillips screws holding the panel in place.
    • These screws cannot be removed completely from the panel. They are fastened to the panel to avoid loss.
  5. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 5, image 1 de 1
    • To remove, lift up the panel's tab.
  6. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 6, image 1 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 6, image 2 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 6, image 3 de 3
    • Remove the screws attaching the hard drive and bracket.
    • Four 4.6 mm Phillips screws.
  7. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 7, image 1 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 7, image 2 de 3 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 7, image 3 de 3
    • Lift up the black tab to expose hard drive.
    • Grab the hard drive bracket and pull to remove.
  8. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 8, image 1 de 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 8, image 2 de 2
    • Remove the screws attaching the hard drive to hard drive bracket.
    • Four 3.6 mm Phillips screws.
  9. Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 9, image 1 de 2 Toshiba Satellite L45-S7423 Hard Drive Replacement: étape 9, image 2 de 2
    • Separate the hard drive from hard drive bracket to complete removal.
Stephen Sippel
Membre depuis le 04/16/13
194 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 21-54, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 1,655
