Aller au contenu principal
Toshiba Satellite L45-S7423 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L45-S7423 Keyboard Replacement, Battery: étape 1, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement, Battery: étape 1, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 2, image 2 de 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 3, image 2 de 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Keyboard Replacement, Bottom Access Panel: étape 4, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement, Bottom Access Panel: étape 4, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement, Bottom Access Panel: étape 4, image 3 de 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 5, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 5, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 5, image 3 de 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Keyboard Replacement, Keyboard: étape 6, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement, Keyboard: étape 6, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement, Keyboard: étape 6, image 3 de 3
    • Remove the two screws holding the keyboard in place.
    • Two 5.7 mm Phillips screws.
    • 'KB' is written alongside the screw holes. This indicates the screws hold the keyboard in place.
  7. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 7, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 7, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 7, image 3 de 3
    • There are three tabs holding the keyboard in place.
    • They are located under the ESC, F8, and DEL keys.
    • Expose the tabs by pressing down on adjacent keys.
  8. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 8, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 8, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 8, image 3 de 3
    • While you press down the ESC key, push the tab with the spudger to release that side of the keyboard.
    • Use a finger to prevent the keyboard from locking back in place.
    • Repeat the previous step for the tabs under the F8 and DEL keys.
  9. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 9, image 1 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 9, image 2 de 3 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 9, image 3 de 3
    • Pick up the keyboard. This exposes a cable that connects the keyboard to the laptop.
    • Lift the keyboard gently. The cable connecting it to the computer is a ribbon. If pulled too hard, the ribbon may be damaged.
  10. Toshiba Satellite L45-S7423 Keyboard Replacement: étape 10, image 1 de 2 Toshiba Satellite L45-S7423 Keyboard Replacement: étape 10, image 2 de 2
    • Gently unplug the ribbon cable connecting the keyboard to the laptop by pulling horizontally.
3 autres ont terminé cette réparation.
Stephen Sippel
Membre depuis le 04/16/13
194 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 21-54, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 membres
18 tutoriels rédigés
Un commentaire
Great instuctions plus photos. Spot on, tx
Darrell - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 17
Total : 3,296
