Introduction
The optical drive reads the CD/DVD when inserted into the laptop. It is not unusual for the optical drive to go stop working or malfunction as there are numerous moving parts. This device is designed to be easily replaced in the case it does malfunction.
Pièces
Aucune pièce nécessaire.
Make sure the battery lock switch is switched to the unlocked position.
  • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Ajouter un commentaire
Slide the battery release switch to the left.
  • Slide the battery release switch to the left.
  • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  • Using a finger, lift up the battery.
  • The battery release switch must be held in place.
  • Remove the two screws holding the hard drive panel down.
  • These screw are permanently fastened to the panel; they are designed to be removed only partially.
  • Use a finger to lift up on the tab and remove the panel.
  • Remove the screw that holds in place the optical drive.
    • One 4.6 mm Phillips screw.
  • Locate the small rectangular hole and insert the spudger.
  • Gently slide the metal flange to the right to dislodge the optical drive.
  • The optical drive will become partially exposed.
  • Pull the optical drive to remove it from the computer body.
Stephen Sippel
Membre depuis le 16/04/2013
167 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 21-54, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 11
Total : 661
