Introduction
This guide will demonstrate to the user how to remove and install new RAM into their laptop. RAM is often upgraded on the laptop to increase performance and is therefore made easy to replace.
Make sure the battery lock switch is switched to the unlocked position.
  • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Ajouter un commentaire
Slide the battery release switch to the left.
  • Slide the battery release switch to the left.
  • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  • Using a finger, lift up the battery.
  • The battery release switch must be held in place.
  • Remove the 5 Phillips screws holding the panel in place.
  • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  • Use a finger to remove the panel by lifting up on the provided removal tab.
  • Pull apart the two tabs holding the RAM in place.
  • Upon release, RAM will automatically pop up.
  • Gently pull on RAM to remove.
Stephen Sippel
Membre depuis le 16/04/2013
167 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 21-54, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 1,014
