Aller au contenu principal
Toshiba Satellite L455-S5046 The Fan Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite L455-S5046 The Fan Replacement, Battery: étape 1, image 2 de 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: étape 2, image 1 de 1
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: étape 3, image 1 de 1
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: étape 4, image 1 de 2 Toshiba Satellite L455-S5046 The Fan Replacement: étape 4, image 2 de 2
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: étape 5, image 1 de 2 Toshiba Satellite L455-S5046 The Fan Replacement: étape 5, image 2 de 2
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: étape 6, image 1 de 1
    • Now gently lift the fan and pull out.
Daryl Spurgeon
Membre depuis le 01/10/17
610 Réputation
6 tutoriels rédigés
Équipe
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Membre de l'équipe Oakland University, Team 2-1, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 291
