Introduction
The CPU is what makes the computer work. If it is not working properly, the computer may not turn on or work in the way in needs to. This guide will show how to replace the CPU through a series of steps.
Ce dont vous avez besoin
Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
11 autres ont terminé cette réparation.
Un commentaire
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
