Aller au contenu principal
Toshiba Satellite L455D-S5976 Optical Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 2, image 1 de 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 3, image 1 de 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Optical Drive: étape 4, image 1 de 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 5, image 1 de 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 6, image 1 de 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 7, image 1 de 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 8, image 1 de 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 9, image 1 de 2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 9, image 2 de 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 10, image 1 de 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 10, image 2 de 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 10, image 3 de 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 11, image 1 de 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 12, image 1 de 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 13, image 1 de 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 14, image 1 de 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 14, image 2 de 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 14, image 3 de 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 15, image 1 de 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 Optical Drive Replacement: étape 16, image 1 de 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
2 autres ont terminé cette réparation.
NateJohnson
Membre depuis le 01/26/14
1 047 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-26, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,182
